Shuaib Posted June 25, 2020 Posted June 25, 2020 I want to Connect Loyverse POS to our Website (shopify platform) is there any Possibility.? 1
Androidez Posted June 26, 2020 Posted June 26, 2020 I'm looking for this solution too. Wouldn't mind paying to have it done (a plugin or something). Can you guys make this possible? 1
Yasu Posted July 6, 2020 Posted July 6, 2020 Hello, I'm Yasuaki. We are now preparing such integration. We will make it available as soon as possible. Best regards, 1
GhostHitman007 Posted August 3, 2020 Posted August 3, 2020 On 7/6/2020 at 6:49 AM, Isobe_Yasuaki said: Hello, I'm Yasuaki. We are now preparing such integration. We will make it available as soon as possible. Best regards, Can't wait! Btw, how this Integration will work? Am I able to add products right now on Shopify or do I have to wait for the integration app? Because, my Shopify is empty right now. I haven't add products. I have a lot of, I mean a LOT of products to add. I don't know what should I do. Do I have to wait?
Yasu Posted August 3, 2020 Posted August 3, 2020 Hello @GhostHitman007, I would suggest to create item in Loyverse POS. Then, you will be able to copy those items into Shopify. May I know how many items do you have?
GhostHitman007 Posted August 3, 2020 Posted August 3, 2020 Over thousand individual items. We are already using Loyverse POS in our store and we are happy. I am just worried about the online store part. Should I add products right now on Shopify or do I have to wait for the integration app to do that? Because, I don't want add items on Shopify again. That's what I am worrying about.
Yasu Posted August 3, 2020 Posted August 3, 2020 Thank you for the question. The integration will have function to transfer item data from Loyverse into Shopify. (But Shopify might have more detailed description of item which we might not be able to copy from Loyverse. For example, description of item which appear in eCommerce website.)
GhostHitman007 Posted August 3, 2020 Posted August 3, 2020 2 minutes ago, Isobe_Yasuaki said: Thank you for the question. The integration will have function to transfer item data from Loyverse into Shopify. (But Shopify might have more detailed description of item which we might not be able to copy from Loyverse. For example, description of item which appear in eCommerce website.) Thank you. So, that means I have to wait for the Integration app. Then I will be able to transfer items from Loyverse and sync items stock between two platforms, right?
Yasu Posted August 3, 2020 Posted August 3, 2020 2 minutes ago, GhostHitman007 said: Thank you. So, that means I have to wait for the Integration app. Then I will be able to transfer items from Loyverse and sync items stock between two platforms, right? Yes, I recommend it. 1
GhostHitman007 Posted August 3, 2020 Posted August 3, 2020 @Isobe_Yasuaki thank you! I hope it's release soon.
Chiara Posted September 17, 2020 Posted September 17, 2020 Hi is there any update on the integration? i'm looking for it too and i would not mind to pay if works and done properly
Jopana Posted November 2, 2020 Posted November 2, 2020 Hi, any update on this? This is important to sync Inventory to keep it up to date.
Kosmos Posted November 3, 2020 Posted November 3, 2020 Hello, we have a Shopify integration for Loyverse and offer an additional 25% discount to Loyverse clients. There are no setup fees and we have a 14-day free trial. https://www.kosmoscentral.com/integrations/connect-loyverse-pos
Featured Comment doko Posted January 8, 2021 Featured Comment Posted January 8, 2021 you can try the application https://loyverse.com/marketplace/shopify 1
Posted by doko,
1 reaction
Go to this post
