EricD Posted January 22 Share Posted January 22 Hi, Our shopkeeper needs to make a partial refund. I am not with her, but as I have Loyverse on my phone, she would prefer me to do it directly instead of her doing it on the POS. I am able to access the receipt but I am getting a message saying that to perform a refund, I must open a shift. Why should I open a shift on my phone while there is a shift open on the POS? Is there another way for me to do it remotely? What would be the implication of opening a shift on my phone? Thanks in advance Link to comment Share on other sites More sharing options...
Solution Georg Posted January 23 Solution Share Posted January 23 18 hours ago, EricD said: Our shopkeeper needs to make a partial refund. I am not with her, but as I have Loyverse on my phone, she would prefer me to do it directly instead of her doing it on the POS. I am able to access the receipt but I am getting a message saying that to perform a refund, I must open a shift. Why should I open a shift on my phone while there is a shift open on the POS? Is there another way for me to do it remotely? What would be the implication of opening a shift on my phone? Hello Each POS device has its own shift report. To access the POS App, it is necessary to open a shift. If you plan to use your POS only to make refunds, you can keep the shift open on your phone without needing to close the shift. After you open a shift, you will be able to see the receipts made on other POS devices (in one store). Then, you can make the refund of the receipts: How to Issue a Refund on Loyverse POShttps://help.loyverse.com/help/how-issue-refund-loyverse-pos 1 Link to comment Share on other sites More sharing options...
EricD Posted January 23 Author Share Posted January 23 Great, Thanks a lot for your answer. 1 Link to comment Share on other sites More sharing options...
