Webhooks and Security for Pay-later payment method
I'm currently building a solution to add "Pay Later" functionality in Loyverse Pos. I'm using the service of Klarna In-Store for this, which is specifically designed for physical stores.
My current solution works by adding a Klarna-payment method inside Loyverse. A receipts.update webhook triggers the integration with Klarna and creates a new payment-session with a copy of the receipt inside Klarna. A separate web interface allows to complete the payment method, by sending a form to the users phone (email/phone/QR). (They have to fill it in for credit-checks etc.) Also refund-receipts are synchronised to Klarna, so the customer only has to pay for what they keep.
Now I want to validate the webhook for security, but it seems the mentioned headers are not sent currently.
Also the validation algorithm seems to be missing from the docs;
https://developer.loyverse.com/docs/#section/Webhooks-overview/Validate-notifications
Any information about this?
Webhook was created  by token created by Oauth2 authorization?
Edited by Jay Rock
Hmm, I did not. I created it from the Loyverse dashboard
That could be a difference indeed, I will test again. Thanks!
Edited by Gemma
I created the webhook using the api, authenticated with OAuth2 and it works now! Thanks again.
I was able to validate the webhook using the following PHP-function;
hash_hmac('sha1', $data, $key, false)
  • 3 months later...
Hey @Gemma, could you please instruct me how to set up webhook using the api, authenticated with OAuth2? I am struggling with setting up wedhooks. Thanks in advance.
