AndreB Posted July 4, 2020 Posted July 4, 2020 Good day, Why cant generic bluetooth scanners work ? We have one store that we have been testing Loyverse on an android tablet for a few months and not we are looking at using some apple ipads we have. we got some about 10 generic scanners from netum . why can't we have to work with Loyverse ? the iPad connects to it via Bluetooth without issue.. please help 1
Solution Andy Posted July 5, 2020 Solution Posted July 5, 2020 Hello. Loyverse POS on IOS devices supports only following scanner models: Socket Mobile 7Ci Socket Mobile 7Qi Socket Mobile S700 Socket Mobile S740 Socket Mobile S800 https://help.loyverse.com/help/supported-barcode-scanners
AndreB Posted July 16, 2020 Author Posted July 16, 2020 Is any work being done to allow any other bluetooth scanners?
Andy Posted July 17, 2020 Posted July 17, 2020 There are two necessary conditions to add any Bluetooth (or USB) device to the supported hardware list for iOS. 1) This device should be licensed at MFi Program ("Made for iPhone/iPod/iPad"). 2) We need to have this device, to develop the connection in Loyverse POS to the hardware. For now, we do not have such bar-code scanners.
alfa Posted August 14, 2020 Posted August 14, 2020 This is probably the only irritating aspect about Loyverse. The socket scanners are expensive and don't work well. Loyverse, please expand the selection to other brands.
Andy Posted August 15, 2020 Posted August 15, 2020 12 hours ago, alfa said: This is probably the only irritating aspect about Loyverse. The socket scanners are expensive and don't work well. Loyverse, please expand the selection to other brands. Could you recommend some scanners licensed at MFi Program? 1
HOK Posted January 11, 2021 Posted January 11, 2021 Yes, I have this awesome iOS supported Bluetooth scanner MunshiG NT-1698LY. One of the low cost and better scanning performance. We use it a lot in India. Could you please add it to supported devices list? 1
DNDJ Posted November 7, 2022 Posted November 7, 2022 I have a Netum NT-1228BC Bluetooth scanner that connects perfectly with an iPad. The scanner is not working during sale, but does working on encoding barcode and searching. Deeply regrettable that a scanner recognized by iOS and with the correct protocol cannot fully work in Loyverse. 1
HuwRees Posted January 30, 2023 Posted January 30, 2023 I would also like to see a wider range of scanner options for IOS. The supported Socket Scanners are very expensive and becoming obsolete. This is preventing us from using scanners with loyverse. 1
Hick Posted February 23, 2023 Posted February 23, 2023 I have a usb scanner and it works in IOS and in loyverse if I select to search and scan barcode however does not work as a scanner only as like a keyboard into text fields. So irritating that it works. Reads the barcode but loyverse does not seem to recognise it. 1
