How long can I keep open tickets?
Go to solution Solved by Omar2019,
How long can an open ticket be kept without being deleted?
You can keep them open as long as you would like, but need to make sure not to log out or you might risk loosing them
Additional information:
If the open ticket is created and saved while offline (without internet connection) and then you log out, then it will definitely be lost. This is the same for receipts, if you make a sale and charge it while offline then log out, you will loose those receipts
