Is it possible to print a receipt twice?
I think that the easiest way is to put 2 printers for receipt printing. So they will print simultaneously the same receipt, and you will get to copies of the same receipt.
  • 5 months later...
Wondering if there is a way to print duplicates of tickets/order dockets.
We usually use 2 copies of the order for 2 stations listing the same items so that we can coordinate each other and have items delivered to customers at the same time. Also, it would be handy to have the function of reprinting the ticket in case the original one gets lost by mistake or the printer fails to connect (like it has been happening in these days...) and print straight away. At the moment I am printing a tax receipt and order ticket to have the duplicates but the tax receipt does not show the comments and ticket number/name/table number.
I think this would be a useful feature to have.
Do you use 2 printers for 2 stations? Or you print tax receipt for the second station for each order?
We use only one printer for both stations.
  • 2 months later...
Could you tell me how to print the the same recipe more than two times?
Hi. You go to receipts. You will find the list of receipts. Just click on the one you need and click print.
  • 2 months later...
This feature recently was released on iOS POS. For Android POS it will be released a bit later.
More details read here.
  • 8 months later...
Dear Community
Is it possible to print the same coupon twice as default setting?
Many thanks
Kind Regards
Christoph
Yes, I believe you have to click on receipts and print again.
  • 4 months later...
It is not possible to print the receipt twice as default settings when you finish a sale. Only 1 copy  of the receipt will be printed.
If you want to reprint a receipt you have to go to the Receipt list in the POS app-> find the receipt you want to reprint -> Tap on the receipt in the list to see its details-> Click the three dots menu (⋮) at the upper right-hand corner-> click on  ‘Print receipt’
You have to follow these steps for each receipt you want to reprint.
  • 3 months later...
If you’re using a non-thermal receipt printer you can use carbonless receipt paper so you can have a duplicate copy. Hope this help.
It is not possible to use a non-thermal receipt printer with Loyverse POS.
Can I programme my till to print two receipts at the point of sale.
  • 2 months later...
Hi, is there a way to find out if the receipt was printed twice?
Hi Team Love the software this is the only thing missing from Android, any time frame on being able to print a food order 2x or as default ? That is a must, the print can come from the same printer. Then the kitchen can take one and the server can have one.
Thank you for your feedback! I will send your feedback to our development team.
Hi there. Has this feature been implemented - to be able to print each receipts twice by default?
No, this feature has not been implemented yet.
