RobKnight Posted December 5, 2024 Posted December 5, 2024 Hi, I am using a KDS on a Chromebook. It works fine as a Kitchen Display but will not print the order. I've attached an Epson TM-T88V printer via USB. I use the Epson Utility App to connect the printer, and the utility performs successful tests on the printer. The KDS displays orders just fine but does not print them. I have the Printer set up as a Kitchen Display with Print Orders switched to "On" and with the correct Printer Group selected. The only odd thing is that when I show the Settings on the KDS, it has "<unknown ssid>" for the Wi-Fi Network, and the IP Address is incorrect. The network only has one router and uses DHCP. The IP Address entered on the Printer Screen in the POS is taken from the Chromebox's Network Information - I think that is why it displays correctly. Any ideas to help KDS display/use the correct SSID and IP - or, it doesn't matter. THANKS!!!
Tanaka_Shotaro Posted December 10, 2024 Posted December 10, 2024 Hello. KDS does not print orders from printers. Only POS app can print orders from a printer.
RobKnight Posted December 10, 2024 Author Posted December 10, 2024 (edited) So, does there have to be a POS in the kitchen to receive kitchen order print outs? That seems odd. Thanks for the answer. Edited December 10, 2024 by RobKnight
Tanaka_Shotaro Posted December 3, 2025 Posted December 3, 2025 If you connect the POS and kitchen printer via an Ethernet cable, the POS and kitchen printer do not need to be next to each other.
