Ferdie Posted August 3, 2024 Posted August 3, 2024 Hello, i would like to get help in optimizing the printing of receipt using Xprinter XP-58iih on Android phone. The printed output to receipt has spaces in between lines causing undesirable POS paper consumption due to long receipt printed.
Georg Posted August 3, 2024 Posted August 3, 2024 6 hours ago, Ferdie said: Hello, i would like to get help in optimizing the printing of receipt using Xprinter XP-58iih on Android phone. The printed output to receipt has spaces in between lines causing undesirable POS paper consumption due to long receipt printed. Hello Unfortunately, there are no settings in the Loyverse POS to reduce space between the lines on a receipt. But you can try to search for a solution in the manual of your printer.
tharwat_group Posted April 14, 2025 Posted April 14, 2025 If you trying to reduce cost , at the long run , it can be done by using the 85 mm printers that uses smaller rolls which definitly will reduce the cost
