Loyverse and Zoho Inventory Integration with Zapier
Zoho Inventory Integration with Loyverse using Zapier Platform
In Zapier, there are templates to use to integrate Loyverse and Zoho Inventory. There are 3 available templates on Zapier to choose from:
The templates created are for syncing created items from Loyverse to Zoho Inventory and vice versa, and the other template is to sync Receipts from Loyverse to Salesorders on Zoho Inventory.
These are designed to make the flow easier between syncing of data so that unnecessary and tedious steps are avoided. For example, Add New Loyverse Items from Zoho Inventory uses the Loyverse Create Items trigger to look for any new items created or updated and then automatically creates the said items onto Zoho Inventory.
