Alex1294 Posted November 5, 2023 Posted November 5, 2023 (edited) Hi, I am currently using Samsung Galaxy Tab A9+5G. Whenever after I scanning the item, and then tap in search symbol, the virtual keyboard does not appear and after that, it's error. I try tap anywhere, it's still error. I already try to redownload the app, and it's still same problem occurred. Do u guys know how to fix this issue? In my old device, Galaxy Tab A7. This problem never occurred, whenever I tap in search symbol, after scanning product. The virtual keyboard Immediately appear, no problem at all. Edited November 5, 2023 by Alex1294
Yasu Posted November 6, 2023 Posted November 6, 2023 Hello @Alex1294 When you connect a barcode scanner to an Android device, the Android OS would recognize the scanner as a keyboard. That may be why the Galaxy Tab A9 doesn't show a virtual keyboard. Therefore, you may need to check into Android settings.
