Freebeeezz Posted October 19, 2022 Posted October 19, 2022 Hello, We just started today with Loyverse POS on an iPad 7 generation with the latest IOS The receipt printer is a TSP100 LAN connected with the cable to the router and the iPad and the printer has there own fixed IP-adress I tested the setting the last day's and was working fine. Today in our store with real customers the printer cannot print because the connection is somehow lost and the Loyverse POS app cannot locate the printer. After exit the Loyverse POS in the iPad and switch the Star printer off, then switch the printer on and launch the Loyverse POS app again everything works fine, but after a few minutes the problem occurs again Any solutions for this problem? Hope to hear soon from you .... With regards .....
Freebeeezz Posted October 20, 2022 Author Posted October 20, 2022 Found out yesterday that just resetting the Loyverse POSS app and relaunch it, the app will find the printer, after losing the connection after a few minutes again. So it's look like a bug in Loyverse POS? Any comments?
dazemc Posted March 31, 2023 Posted March 31, 2023 I am experiencing the exact same issue. I have tried both setting the printer to static and a dynamic (DHCP) IP, as well as extending the printers connection timeout. Basically, I have ruled out this being a printer issue. I have not checked ios vs android though
Freebeeezz Posted April 1, 2023 Author Posted April 1, 2023 Yes, still the same problem here. Fortunately my clients don't need a receipt much, so if a client need one I restart the app, then I can use the printer, but after a few minutes the app looses the connection to the printer. The cash drawer I operate manually.
institution Posted May 2, 2023 Posted May 2, 2023 Has anyone found a way round this as I have the same problem. I was fine with an older Loyverse but on updating the app my printer keeps losing connection.
