JANELIMST Posted October 20, 2021 Posted October 20, 2021 HI We would like to ask for help on the integration of Gkash Payment Gateway to your loyverse system. pls refer to the attached API documentation. Thanks
Yasuaki Posted February 17, 2022 Posted February 17, 2022 Hello. Thank you for your suggestion. Unfortunately, payment type integration can't be done by using API right now. May I know how much Gkash is popular? As I understand, it is a payment gateway in Malaysia, is it correct?
