Is Loyverse compatible with build-in SUNMI V2 PRO barcode scanner ?
Hello ,
I have a question, Is Loyverse compatible with build-in SUNMI V2 PRO barcode scanner ? if yes, then how to do the setup ?
Thanks,
Adel
Yes it is, i received my v2 today and tested it.
To get it working do the following :
Device settings
scanner setting
scan trigger : on screen button
Scan mode : i left it on trigger mode.
A orange icon should appear on the screen.
then go back to loyverse.
when you press that orange button it will activate the scanner and you can read barcodes.
