Is it possible to use barcodes with embedded prices?
Go to solution Solved by Edward,
Hi @Haricot, it is not possible to have barcodes with embedded prices. You can only have barcode with embedded weight.
Hi Edward. Thank you for the answer. Appreciate the assistance.
