Stephan Posted July 22, 2021 Posted July 22, 2021 Wondering whether I could use an Android Box, which is linked with an HDMI Cable to a 45 Inch Flatscreen in our kitchen, as display for Loyverse KDS. Basically, I can install Loyverse KDS on the Android Box and start but get an error message "Connection Error" immediately. Loyverse POS and KDS are connected to the same network, the setup was done according to the instructions and if I use another Android Tablet, it works. Just the Android Box won't work. Any ideas or experiences on how to address this? Thanks for your support in advance.
ifko Posted August 9, 2021 Posted August 9, 2021 I get the same error when starting kds on my tablet but it works fine. Have you tried to put in some orders anyways?
Stephan Posted August 9, 2021 Author Posted August 9, 2021 Hi Ifko, thanks for your information and support. In the meantime, I got it working, too. Had to upgrade the Android Box and connect to a 2.4 GHz network instead of 5 GHz.
