Coffeecasa Posted February 2, 2021 Posted February 2, 2021 (edited) Hi, installed everything, test print works but any other order I tried does not come to the kds. I selected all the categories to make sure they get sent to the kds. any ideas what I can check? Thanks Edited February 2, 2021 by Coffeecasa
Andy Posted February 3, 2021 Posted February 3, 2021 Hello. Please, check the WiFi connction of mobile devices with POS and KDS. Details are here: Troubleshooting When Working with KDS
Terinotperry Posted April 19, 2021 Posted April 19, 2021 I am having the same problem and have gone through the troubleshooting Andy provided. Did you ever get it to work?
Terinotperry Posted April 19, 2021 Posted April 19, 2021 After connecting my pos device to my tablet with the KDS app, the test order came right over to the KDS but when I create an order it never shows up on the KDS.
Solution Andy Posted April 20, 2021 Solution Posted April 20, 2021 You have to create create a printer group in the Kitchen Printers menu and assign categories of items. KDS displays only items from the printer group. Please, check details in the tutorial: https://help.loyverse.com/help/kds-configuration
Coffeecasa Posted April 20, 2021 Author Posted April 20, 2021 My problem was the non static ip adress of the tablet
Derksy Posted May 8, 2021 Posted May 8, 2021 Having the same issue, The test order came through perfectly but new orders do not. Same wifi network and printer group created and on. Using Android tablets
Jardin Posted June 8, 2021 Posted June 8, 2021 Having the same issue, same network, kitchenprinter found by the device, printer group created, Test comes through but no order. Maybe an Android version issue?
Derksy Posted June 10, 2021 Posted June 10, 2021 I figured out you need to send the order to printer, then it shows up on the kitchen display
