Guadalkitren Posted April 17, 2021 Posted April 17, 2021 Hello, please, sorry for translation errors. I would like to know if it is possible to install Loyverse APP in a POS terminal based on adroid 7 that incorporates thermal printer, and NFC readers .... for cards. I have purchased the POS terminal in Aliexpress, but unfortunately I cannot use LOYVERSE with the printer function, because it does not recognize it, since it is a printer that is directly connected to the motherboard, I think it is via serial port. The seller has sent me the SDK development package of the device to do programming, but I have no idea. The POS terminal comes with a demo APP to test the peripherals, card readers and printer that is included in the development files. I could use a little help if someone in the know were able to adapt LOYVERSE to work with my POS terminal. I put here the download link of the SDK development package in case someone of you can at least tell me if it is possible. Thank you. https://mega.nz/file/fw1jBaLb#SdXj7B5aHz58p0HSflMis0Edce-s1XEiYO8uiWv5hmw
Solution Andy Posted April 20, 2021 Solution Posted April 20, 2021 Hello. The best way is to obtain the device from the list of supported hardware that Loyverse can work with the built-in printers.Connecting Built-in Printers on Sunmi DevicesLoyverse POS Works on iMin Devices
