Star mPOP barcode scanner not responding with Android
I got a Star mPOP cash drawer with the scanner attached to it.
I did have an iPad, and it was working perfect.
Now I have a android tablet, but the barcode scanner is not responding in Loyverse.
It does work when using the mpop utility, so the scanner works.
The Star mPOP is connected with bluetooth to my android tablet and the scanner is connected by USB to the mpop.
Anyone any idea how to get it working on android?
Thanks.
  • 4 months later...
Have you found a solution, I have the same problem right now?
  • 3 weeks later...
Hi has anyone found a solution for this as I'm having the same problem. Any help would be appreciated
  • 4 weeks later...
Anyone a solution? i`ve the same problem now with my android tablet. With my ipad i dont have this problem. @loyverse please an answer
Hi Fessler83.
I tried everything I could including but not limited to buying a otg lead  but no solution. I ended up buying a usb scanner recommended by Loyverse which is working awesomely let me know if u want the model bought and I will share it with u
Hello everyone! Got the same issue. I assume no one found a solution for this? Connected via USB. Works fine with mpop utility but nothing happens in Loyverse.
