Compatible SumUp readers
Go to solution Solved by Mag,
I'm trying to understand what SumUp card readers are compatible with Loyverse and what the integration level is.
In the UK there are 3 models available:
- SumUp Air Card Reader
- SumUp 3G Card Reader
- SumUp 3G Card Reader with printer
Are all three compatible with Loyverse?
Is the 3G (with WiFi) available to all POS devices on the same WiFi network or does it only connect to one device via Bluetooth?
Is the printer variant compatible for printing the Loyverse receipt or is it just the SumUp transaction printed?
If it can print a Loyverse receipt, can it print receipts for cash transactions and bills for each table?
  • 7 months later...
I have 3 sumup 3G card readers, so they are not compatible with Loyverse?  Only with SumUp Air Card Reader?
I am afraid to say that at the moment we only support SumUp Air/Plus reader.
  • 1 month later...
Any idea whether this wil change in the future?  e.g. SumUp Solo?
It seems that it should have been already sought after, integrating SumUp Solo with loyverse. It can be used as a customer display in addition to the expected integration of payments. What needs t make this happen?
  • 3 months later...
También funciona con el solo a través de actualización y activación de bluetooth. Saludos
