Is it possible to sell an article by using the SKU number?
Go to solution Solved by Mia,
hi,
is it possible to sell an article by using the sku number?
You can search items by SKU in the sales screen by writing the SKU in the search field:
You can also print labels for your items by choosing as a barcode source field the SKU and then you can scan this barcode and the item with the corresponding SKU will be added automatically in the receipts.
You can refer to these help materials for your guide:
-How to Print Labels for Items
-How to Sell Items Using Barcode Scanners
  • 4 years later...
The problem is, that the item isn't found, but the category and you still have to search for the item. Is there a workaround?
You should be able to search for an item on the sale screen using the SKU of the item, its barcode number or its name:
For example:
You can search for an item using the item's SKU (10006):
Or by typing or scanning it's barcode:
