When I scan barcode (weight type) same product 2 times, receipt will auto merge both weight together.
Go to solution Solved by Mia,
But I want to show weight each package on receipt.
When you scan the barcode of the same item twice, the item will appear only once in the receipt with the total quantity (weight).
It is not possible to show the weight of two packages separately if it is the same item.
However, I would be happy to forward your suggestion to the development team and this feature might be added in the future.
