How to connect a barcode scanner to Sunmi?
Go to solution Solved by Iscander,
I want to buy a "Sunmi T1-mini" POS device. Can I connect barcode scanners to this system? If yes, then what the scanner model?
Hello, Alex. I have this device that you want to buy. This device has a USB port. You can connect a USB scanner. The Sunmi phone already has a camera(scanner) but it is not as convenient as a USB or Bluetooth scanner. I am using a Posiflex scanner. If I understand and have seen, all non-phone type devices(Sunmi) have a USB port for the scanner.
Edited by Iscander
