kj1206 Posted September 7, 2019 Posted September 7, 2019 hi I want to invest in hardware kit I am thinking 1 ,Ipad pro 12.9 2nd or 3rd Gen ( For POS) 2. Ipad as customer display For printer can I use Star mC-Print3™ As for drawer do I need to star cash drawer or APG cash drawer? Please advise extract make and model number which works with Star mC-Print3™ and Ipad As well which barcode scanner will work USB one will work? Please advise extract make and model number I have seen hardware page https://loyverse.com/hardware but it only shows SocketScan Bluetooth scanners for Ipad which are the worst ones going by reviews on internet. Can someone confirm USB barcode scanner can work with iPad since receipt printer has functionality with up to 5 interfaces including Star CloudPRNT as well as hub functionality, controlling select USB peripherals attached to the printer including cash drawer, scanner and kitchen buzzer. I have also thought of plan b in case Ipad option does not work Instead getting Ipads I get Lenovo - Yoga C630 2-in-1 15.6" Touch-Screen Chromebook for pos https://www.bestbuy.com/site/lenovo-yoga-c630-2-in-1-15-6-touch-screen-chromebook-intel-core-i5-8gb-memory-128gb-emmc-flash-memory-midnight-blue/6295998.p?skuId=6295998 For printer Star mC-Print3™ and Usb cash drawer Usb barcode scanner will work with it? I will need to know that can I setup customer display by getting a android tablet will it work with Chromebook as a customer display? Thankyou
doko Posted September 8, 2019 Posted September 8, 2019 On 9/7/2019 at 11:58 AM, kj1206 said: I will need to know that can I setup customer display by getting a android tablet will it work with Chromebook as a customer display? Great question. Yes Loyverse KDS works with Chromebook. You can also connect a printer to your Chromebook.
Yasuaki Posted April 9, 2025 Posted April 9, 2025 Hello @kj1206 Thank you for your post. On 9/7/2019 at 11:58 AM, kj1206 said: As for drawer do I need to star cash drawer or APG cash drawer? Please advise extract make and model number which works with Star mC-Print3™ and Ipad As well which barcode scanner will work USB one will work? Please advise extract make and model number I have seen hardware page https://loyverse.com/hardware but it only shows SocketScan Bluetooth scanners for Ipad which are the worst ones going by reviews on internet. -> Loyverse POS on iOS is compatible only with Socket scan. Can someone confirm USB barcode scanner can work with iPad since receipt printer has functionality with up to 5 interfaces including Star CloudPRNT as well as hub functionality, controlling select USB peripherals attached to the printer including cash drawer, scanner and kitchen buzzer. -> Loyverse is not compatible with Star CloudPRNT. I have also thought of plan b in case Ipad option does not work Instead getting Ipads I get Lenovo - Yoga C630 2-in-1 15.6" Touch-Screen Chromebook for pos https://www.bestbuy.com/site/lenovo-yoga-c630-2-in-1-15-6-touch-screen-chromebook-intel-core-i5-8gb-memory-128gb-emmc-flash-memory-midnight-blue/6295998.p?skuId=6295998 For printer Star mC-Print3™ and Usb cash drawer Usb barcode scanner will work with it? ->A cash drawer connects to your receipt printer and is triggered to open automatically when you finish a cash sale. Most of receipt printers have a special cash drawer connector, usually of RJ12 type. Refer to your receipt printer and cash drawer manuals to make sure they are compatible. I will need to know that can I setup customer display by getting a android tablet will it work with Chromebook as a customer display? -> We don't officially support Chromebook. Thankyou
