Las-Cascadas-The-Fal Posted September 1, 2019 Share Posted September 1, 2019 Hello, For anyone having trouble with their bills print being cut off from the right, the following command will help: B6,6C,9A just write in the Initial ESC/POS commands area in advanced settings Also you can find more command info that might help other situations in: http://www.ekka.com.ua/files/doc/ma501_4421_00_rev14.pdf Hope it helps! NOTE: Just to clarify, i do not own the MP-4000 TH POS Printer mentioned in the manual, but most commands did work for my off-brand Bluetooth thermal printer, so it might also work for yours 1 1 Link to comment Share on other sites More sharing options...
PeterNZ Posted November 3, 2019 Share Posted November 3, 2019 Brilliant! Thank you this pointed me into the right direction. My problem was solved by adding a 0A to the "Cutter ESC/POS Commands" which added one linefeed. Cheers Peter Link to comment Share on other sites More sharing options...
Fely Posted August 15, 2021 Share Posted August 15, 2021 The receipt when printed has no total. please help. thank you Link to comment Share on other sites More sharing options...
Mag Posted August 17, 2021 Share Posted August 17, 2021 Hello, please check the settings of your printers in the POS. Have you indicated correct paper width or print width in advanced settings of the printer? Link to comment Share on other sites More sharing options...
