MarkW Posted August 19, 2018 Posted August 19, 2018 I tested the Loyalty scheme to see how it worked and looked at the receipts. We won't be using a loyalty scheme and wondered how you remove the information from the receipts?
Alex Posted August 20, 2018 Posted August 20, 2018 Hello, If you're not using loyalty (loyalty % set to 0) and also if customer has 0 points balance then they should not appear on the receipts.
Solution sidorela Posted September 25, 2019 Solution Posted September 25, 2019 Hello, you can read in this link a explanation how to cancel the loyalty program and how to remove loyalty points from the receipts:
