How do I change my phone number in settings?
I need to change the phone that I use as the mobile number I had has now changed.  How do I do this?
Hi! Thanks for reaching out 😊
Could you please let us know where you’d like to change the phone number?
For example, are you trying to update:
- the phone number in your Store settings, or
- the phone number in your Billing details, or
- the phone number in your employee profile
Once we know which one you’re referring to, we’ll be happy to guide you step by step.
