Kimba Posted September 17, 2025 Posted September 17, 2025 Hi All I have the printer set up via ethernet and it works but when I put the printer type to Other and print it spits out and 15 meters of rubbish. What setting should it be set to and should I be changing any advanced settings. Why is it not in the drop down as its a supported printer
Yasuaki Posted September 18, 2025 Posted September 18, 2025 Hello. Thank you for reporting the issue. Could you send me a screenshot of the printer settings and the printed receipt?
Kimba Posted September 19, 2025 Author Posted September 19, 2025 It spits out reems of blank paper with the odd bit of unreadable info like 1/2 a line of junk text and then followed by a meter of white space then bit more text etc
Yasuaki Posted October 3, 2025 Posted October 3, 2025 Hello. Could you please post this printer setting menu?
