nhcw Posted June 6, 2025 Posted June 6, 2025 Hi, im trying to set a lovyverse setup with the TM-t20II Epson printer, ive seen that it is on the supported printers list but it is only marked with the Ethernet option not USB, the problem is, my printer only has a DK port for the drawer and an USB port, how do i make sure that i can work with lovyverse, ive seen that it needs to have status commands and be compatible with ESC/POS commands but i cant find any of that on the manuels or tech sheet. I atach a photo of the connectors
Yasuaki Posted June 10, 2025 Posted June 10, 2025 Hello. If your printer doesn't have an Ethernet port at the back, it means the printer is not supported. Nevertheless, you can try connecting it as "Other model" with "USB" interface, if you use Android for POS app.
