How to use a receipt printer via USB cable and charge my POS tablet at the same time
Hi All,
I'm using Loyverse on an Android tablet (Lenovo P12) and connecting to an Aures 333 receipt printer with a USB cable (USB-B to USB-C) and although it's not one of the supported printers it all seems to work fine.
I only have one USB-C socket on the tablet so I can't use the tablet and charge it at the same time. Does anyone out there found a piece of hardware that would work for splitting a usb-c from my Android into 2 so that I can use one for the printer and the other for charging?
I'd prefer not to spend hundreds on a new bluetooth printer unless this is unavoidable. But also, is there such a thing as a bluetooth adapter for my non-bluetooth printer? I haven't found one.
Any advice welcome. Thanks.
Tony
Hi. You can buy usb c distributor ports.
So you can plug in many connectors.
