Possible to Shrink Receipt Length to Save Paper?
I currently have an Android Tablet and an iPad connected to the same Epson TM-T88V POS Receipt Printer.
On the Android Tablet, I've set it up as TM-T88V, while on the iPad, it's set up as TM-T88VI-i, as that is what's supported.
I've noticed that the receipt printed from the iPad is about 30%-40% shorter in length because the content is more compressed and has reduced blank space. Is there a way to achieve the same compressed format for receipts printed from the Android tablet?
Since both devices use the same printer, I was wondering if there might be a setting or a command, perhaps something involving Initial or Cutter ESC/POS Commands, that could help adjust the formatting on the Android side.
Thank you.
