Wooders Posted May 28, 2024 Posted May 28, 2024 We have 2 android tablets from different manufacturers but both are having the same issue. The range from the tablet to the reader seems very low. With the reader only a small distance away the reader does not connect or transactions fail. Using the reader with iPhone seams OK. Thanks
Shinjin Posted May 29, 2024 Posted May 29, 2024 Hello, Have you tried contacting Zettle customer support? We also recommend making sure that your Android devices are using the latest version of the Loyverse POS app, v.2.39. If you have additional questions or concerns about Loyverse POS, please let us know.
Wooders Posted May 29, 2024 Author Posted May 29, 2024 Thanks Shinjin We have not contacted Zettle yet but as I said on the same site we use the same readers with an iPhone and no issues. I do have an iPad so i'm going to try it with that and see if I get the same problems. Thanks Paul
