card reader
Library_Theatre
I love loyversew, but it wont work with my sumup air card readers anymore, hjis is a sumup issue, as it will only let me use sumup pos, which is rubbish.
Basically i connect in sumup to the card reader, it connect ok. when i then minimise the sumup app or switch to anything else the bluetooth connection drops, sumup dont seem to care, hoping someone has suggestions.
I have restarted / rebooted card reader and tablet multiple times, i have uninstalled the app.
I have re-set Bluetooth
Thank you
TERRY
Thank you for your feedback,
Could you please try updating the Loyverse POS app to the latest version v.2.34.8 on Android and then try again?
We will be waiting for your reply.
have doine so
