Leoma Posted January 3, 2024 Posted January 3, 2024 (edited) I intend to use 3 POS devices (3 iPads for 3 staff) in my business. I have an Epson TM-m30ii printer. How can I connect all 3 devices to the printer to print bill? Thank you. Edited January 3, 2024 by Leoma
Solution Yasu Posted November 8, 2024 Solution Posted November 8, 2024 Hello. These articles explain how to connect printer depending on the interface type. To connect a printer to 3 devices, please repeat the same method to connect printer 3 times. EthernetBluetooth USB with AndroidUSB with iOS
ColoradoBound Posted December 17, 2024 Posted December 17, 2024 On 1/3/2024 at 4:03 PM, Leoma said: I intend to use 3 POS devices (3 iPads for 3 staff) in my business. I have an Epson TM-m30ii printer. How can I connect all 3 devices to the printer to print bill? Thank you. Expand Bluetooth - Based on how the connection types work, Bluetooth is out because a Device can only connect to One connection at a time and that is how it was designed. USB - A USB hub "might" work, but likely not because the printer itself would have to understand the various devices connected to the hub and then itself, I only know of one POS Printer that has a hub built in and it does not allow multiple items to print only as a hub for barcode scanner, etc.. Ethernet - Ethernet is your most likely to work and best case to try, as the device could be assigned a Static IP, each POS connects to that IP as a Printer and sends the data that way. This is likely your best way to try but I would assign an IP to the printer for consistency of connection, as a rotating IP would lose connection for the printer.
