El-Cortijo Posted December 1, 2023 Posted December 1, 2023 I have a printer connected to a Samsung tablet via USB OTG and set it up to print all orders from the Bar print group. When I create orders on the tablet, the orders print, but when I create an order from my mobile POS, it doesn't print anything out. Is this by design? If so, is there any work around?
eastroyce-pos Posted December 4, 2023 Posted December 4, 2023 Is the printer connected to your mobile pos via USB OTG too ? If not, then will not work.
Yasu Posted December 11, 2023 Posted December 11, 2023 Hello @El-Cortijo If you want to connect one printer to two POS, I recommend using an Ethernet interface printer. Please check our supported printer list.
milivanili Posted March 21, 2024 Posted March 21, 2024 Tengo dos impresoras, una en barra y otra en cocina. Hay cuatro camareros, cada uno con un movil, haciendo pedidos en comedor, terraza, barra etc.. Si en algún momento, dos o mas camareros, envian imprimir pedido a la vez, solo se imprime UNO, el camarero no sabe si ha salido su pedido en la impresora. Que solución hay aqui?
