How to generate wifi password and print on receipt
i want print the wifi passcode on the coffee shop receipt and will expire after 2 hours.
i have a hotspot captive portal wifi systems can generate passcode but I don't know how to integrate this passcode into the loyverse system. Is that possible?
There is a simple solution
After configuring the router password
Add it as an item and print it normally instead of editing reciept from the back office
Read more
