The CDS suddenly gets stuck at the ticket screen with some items added after few minutes of use.
I need to force close the app and open it to make it work, but it gets stuck again after few minutes.
Is it happening only to me? 🥺
15 minutes ago, mohu said:
Same here. Please help!
Same here. Any findings?
5 hours ago, mohu said:
Same here. Please help!!
I fixed it uninstalling the last updates and downgrading to the previous versions on Android.
Loyverse POS 2.29 (working ok)
Loyverse CDS 1.1.0 (working ok)
I am using Android, and when I downgraded the version of cds from 1.2.0 to 1.1.0, it returned to normal. The POS version remains up-to-date at 2.30.1. I believe there is a bug in cds 1.2.0.
Same again and downgraded POS version, it works. Thanks Hung.
Edited by mohu
Hello there,
I had the same problem, but when I updated to v.2.30.2, it worked well!
