disable pin code
How can I disable the pincode?
Thanks for your help
It is possible to enter POS without a PIN code only when there are no other users besides the owner. If you have at least one employee or the "Timeclock feature" enabled, the PIN code is obligatory for each user.
In the Edit Employee form of the owner, tap the ‘Disable PIN Code’ button.
Confirm the disabling in the dialog window.
At any time, you can restore the PIN code access for the owner through the ‘Add PIN code’ button.
Hi there,
the button does not appear in the menu
On 4/29/2023 at 11:53 AM, CBD_Experience said:
Hi there,
If you don't see the disable button follow it
Go to settings > Turn off timekeeping
Then go to Staff, select the list of employees, there will be a disable button
