Will the Shift management system require each pos & android to start/finish separate shifts?
Featured Replies
We want to set up a bar with 2 pos terminals,
Pos1 Bar
Pos2 Garden
Each pos will have 1 or 2 android devices for table service, however the androids will not keep the cash but will put that in the bar or garden pos, whichever one they are working from.
Will Shift management system reguire each pos & android to start/finish separate shifts? And therefore will we have 5 shifts per day or 2?
For each device which you want to use for the Loyverse POS Aplication, you need to create a "POS" in the back office:
How to Create, Activate, Deactivate and Delete POS
https://help.loyverse.com/help/how-create-activate-and-delete-pos
Each device will have its own separate shift report.
If you use five devices for the Loyverse POS App, you need to create five POSs in the back office. You will have five shift reports.
