Carabistoule Posted May 25, 2022 Posted May 25, 2022 Hi I just received my Sumup terminal and made some tests. I wasn't aware that Sumup needed to connect on Bluetooth with my phone. I thought everything goes through the internet since it's connected to the wifi. The issue is that I ordered a Bluetooth only receipt printer. Will I be able to use both hardware on the same Bluetooth connection or is there another way to set this up. Thanks!
Featured Comment Andy Posted May 31, 2022 Featured Comment Posted May 31, 2022 Hello. Bluetooth-equipped smartphones can connect to multiple devices at once. The latest Bluetooth 5 specification allows up to 7 device connections simultaneously to a primary device in active mode.
Posted by Andy,
0 reactions
Go to this post
