BSB Posted May 24, 2022 Posted May 24, 2022 hi, Just purchase & setup for IMIN D1 POS Terminal, it has built-in 58mm printer & cash drawer port. Have try to setup printer & connect cash drawer correctly. Manage to test print receipt successfully but drawer is not trigger to open. Have also run IMIN internal hardware test for drawer, success open with no issue. Need some guide for this model. Is there any Drawer ESC/POS commands setup for this? Thanks Note: Have try external USB receipt printer with drawer connect to it, no issue drawer open successfully.
CashRegisterGroup Posted June 15, 2022 Posted June 15, 2022 what printer settings did you select please?
BSB Posted June 16, 2022 Author Posted June 16, 2022 hi, since it is built-in printer with imin D1, i select printer model as [other model] & interface as [USB], print test working for printer but drawer not open.
CashRegisterGroup Posted June 16, 2022 Posted June 16, 2022 try this as its a fix on one of the other imin terminals, For Printer model, choose Other model. For Interface, choose Bluetooth. On the new line that appears below, click the Search button. This should search and then give you the option BluetoothPrinter, select this. select the correct width. You will also want to set the option Print Receipt and Bills to on. It should look the same as below: Once these options have been set, click Advanced Settings. Under the section that says Initial ESC/POS commands, you will want to set the value of Drawer ESC/POS commands to the following value: 10,14,00,00,00. After you have inputted those numbers, click the back arrow at the top left and then hit Save. If you now return to Register mode and finalise a Cash transaction, the drawer should fire, and you should be able to print off a receipt as well.
BSB Posted June 17, 2022 Author Posted June 17, 2022 Thank you very much. Issue resolved with interface bluetooth.
