How to connect Epson TM-T20II (Ethernet) to Loyverse POS?
Go to solution Solved by Robert,
IP address stays at factory defaults. Can anyone give me a step-by-step instruction on connecting printer to the internet? Thank you
However, in many cases you need to change the IP of your printer to match that of your wifi network. For that you need to follow you printers manual, it should be explain how you can do it.
And read this tutorials:
https://help.loyverse.com/help/how-ethernet-printer
https://help.loyverse.com/help/troubleshooting-when-setting
