peterufa Posted November 7, 2017 Share Posted November 7, 2017 Is there a way to correct the sum of the shift which was entered wrong by cashier before ? Link to comment Share on other sites More sharing options...
Lilia Posted November 7, 2017 Share Posted November 7, 2017 It's not possible to do it. If there was a mistake the program wil show a difference, which will help you to identify the problem, and do doublecounting if needed. But it's not possible to fix the difference. It could be a feature request for the Loyverse team. Link to comment Share on other sites More sharing options...
aleem1998 Posted October 7, 2019 Share Posted October 7, 2019 Any fix? Link to comment Share on other sites More sharing options...
Solution Grey Posted October 15, 2019 Solution Share Posted October 15, 2019 Yes if the shift closed. report contains data of the cash drawer and the sales summary at the closing of the shift, including the actual amount of cash and the difference in comparison with the expected amount (Z-report) Which you will not able to edit anyways. Other things if you need to edit the report of the current shift. At the end of the day when you close the shift you will have right amount of money Link to comment Share on other sites More sharing options...
