Tempelscouterna Posted October 1, 2021 Posted October 1, 2021 Hi Has anybody been able to connect a KDS sunning on an ipad to a POS running on android? I have assigned static ips to the KDS and it is running on a separate router. The automatic search for the KDS on the POS says nothing is found, and manually entering the ip of the KDS says it cannot be found. Regards, Tobbe
Shinji Posted October 1, 2021 Posted October 1, 2021 Hello! Perhaps, that is the reason why your POS App is not able to detect your KDS App when entering the IP Address. Please be reminded that when connecting KDS and POS App together both its devices where they are installed should be under the same Wi Fi Router and cannot be connected with different or separated routers. You can check out our guide about how to connect KDS App and configure it for more information: https://help.loyverse.com/help/kds-configuration
Tempelscouterna Posted October 1, 2021 Author Posted October 1, 2021 Thank you for your reply. When I said separate router, I meant I set up a separate network for the Loyverse POS, CDS,KDS and printer. Are you saying that the ios and android apps are incompatible? Because on the same router an KDS running on android will work just fine. Tobbe
Qfc Posted December 30, 2021 Posted December 30, 2021 Please did tou fine a solution ? I have the same problem , POS on ios And KDS on android and it’s unable to fine it.
