Bluetooth printer not yet supported?
Go to solution Solved by Andreait,
Hi I use Loyverse POS with two Bluetooth printers A6, one is a normal generic mtp2 printer, and one is peripage printer. Last week all ok but now I can print with peripage through loyverse. If I use peripage app I can print what I want but I can print in loyverse app. I tried unistalling app, unpair print, but not success.
Someone can help me?
4 hours ago, Edward said:
Hi @Andreait, there is a list of compatible receipt printers which also includes Bluetooth printers. If you printer is not on the list, it means that your printer has not been tested and cannot assure you that it will work properly.
Yes but last week it works. And in mac address line I see name of Bluetooth printer in past i saw mac address. Something changed in Bluetooth find and pairing.
My peripage printer not works but my other printer goojprt still works.
