SamiL Posted July 19, 2021 Posted July 19, 2021 I am using IPAD for Loyverse and would like to use XPrinter XP-N160II with bluetooth. Anyone know does it work? I try to find the printer model in setting, but I can select " Other Model (Ethernet)" only.
Edward Posted July 19, 2021 Posted July 19, 2021 Hi @SamiL, the printer is not on the list of supported printers. Also, since the printer doesn't use ethernet connection, you cannot configure it using the "Other model" option when connecting to an iOS device. You might have a better chance connecting to an android device.
SamiL Posted July 19, 2021 Author Posted July 19, 2021 2 minutes ago, Edward said: Hi @SamiL, the printer is not on the list of supported printers. Also, since the printer doesn't use ethernet connection, you cannot configure it using the "Other model" option when connecting to an iOS device. You might have a better chance connecting to an android device. Too sad, I don't like to use android device, so I prefer to change other POS system. Thank you for your answer.
