dfedosoff Posted March 25, 2021 Posted March 25, 2021 Pardon my ignorance, but I have big problems with devices at my business because i am in a valley (orchard). I cannot get wifi but a new cellular tower has been put up so I now get cellular data connection on my iphone. I want to use Loyverse and print out to a food truck kitchen about 20 feet away from my desk. Is this possible and what requirements would my Ipad and printer require. Or if there is better solution I am open to it.
Solution Andy Posted March 27, 2021 Solution Posted March 27, 2021 Hello. If you have only one POS in your business value, sure, you can use mobile Internet to connect data to the Back office. I would recommend you using a Bluetooth printer. It can work at such a distance if there are any obstacles for radio waves (such as walls) between devices. For iOS devices, it should be the only printer from the Supported printers list.
