Printing orders on a separate POS device
Hi Guys,
Scratching my head here trying to get the Loyverse system the way I need it to.  I want to use one POS device to take orders, and it send the order back to a main 'central' POS device which hosts the printer.
Basically, I need to use a POS device in my beer garden, which will not transmit the bluetooth signal as far as the printer, hence needing that to send signal to a separate POS device for printing.
Does anyone know if this is possible please?
Many Thanks!
Rob
Hello.
Loyverse can sync open tickets between different devices. It means that you can create and save a ticket at one POS and then open it on the other POS.
But the kitchen order is printed automatically after saving the open ticket.
In your case, I would suggest using the Ethernet receipt printer, which allows connecting several mobile devices with different POS.
Please, check tutorials:
Using Kitchen Printers with Loyverse POS
How to Set Up Kitchen Printer for Each Kitchen Station
How to Set Up an Ethernet Printer in Loyverse POS
