Blue Tooth Printer and Cash Draw
Will be using Apple Air 2 as the tablet - will be using a recomended blue tooth printer as the printer needs to be away from the cash draw - question is if using a blue tooth printer will the cash draw open if connected by blue tooth rather than a usb cable - also what is the best card reader to use with this system?
Rgd's Gary
Hello.
You can connect the cash drawer to the receipt printer only by wire (through RJ11 type connector). Please, check how to connect a cash drawer.
You can connect the receipt printer with a mobile device with Loyverse POS via Bluetooth.  Please, check the tutorial: How to Set Up Bluetooth Receipt Printer with Loyverse POS
Note, that with iOS device could be connected only printers from the supported printers list.
thanks for the quick reply - our issue is that the recepit printer needs to 4 meters away from the tablet and cash draw (it will be printing our tickets for a Barista next to the coffee machine) the drinks our made, given to the customer along with the recepit - and their is no way to run a long USB cable from the printer to the cash draw.
  • 3 weeks later...
Can I connect more than one android device to BlueTooth printer in free version of loyverse?
