Talha Posted September 19, 2020 Posted September 19, 2020 Hi I am not able to add dpp 250 printer can someone please guide me how to
Andy Posted September 19, 2020 Posted September 19, 2020 Hello. Do you try to connect this printer to iOS or Android? Which interface do you use (Bluetooth or USB)?
Talha Posted September 19, 2020 Author Posted September 19, 2020 Hi andy I am using Android and connecting with blue tooth.
Solution Andy Posted September 21, 2020 Solution Posted September 21, 2020 You may try to add this printer as "Other model". Check: How to Set Up Other Printers in Loyverse POS But be aware that not every printer may work with Loyverse POS. To be 100% sure, please use a printer from the list of recommended models.
