How to deal with receiving stock? How to update current stock with newly received stock?
Go to solution Solved by Natali,
Loyverse inventory management quite simple and it doesn't provide of many options to update stock. But it does what it's necessary and it allows you to update the stock of your items by reintroducing manually your total stock. Let's say you had 20 of an item, and you received 50 more, then you can change the stock value to 70. Ther is a quick way to input stock values from the back office:
Hi!
Loyverse Team add a bunch of new features called Advanced inventory!
https://loyverse.com/advanced-inventory
With a Purchase order it is possible to order items from supplier, receive it and stock will be updated automatically!
It is really great feature which making life of manager much easier and reduce mistakes!
https://help.loyverse.com/help/how-purchase-orders-and-suppliers
